How to build a treehouse?
kitfriendesq
Building a Reputation
My son keeps asking when we're going to build him a 'proper treehouse' to expand his cubby on stilts in the garden so I figured the xmas break is a good time to start planning. I did stilt based job in the UK so some experience but this one feels like a proper tree-based job is in order, and the kids are noticably bigger now so something chunkier is in order!
Our old UK treehouse:
The tree next to our cubby here is pretty beefy and there's a handy junction for the branches at about the right height so I'm thinking:
- Platform sitting in the notch of the branches, 1-2 "beams" in the notch, and then 1 either side of the tree
- Some 'knee brace' diagonals
- Perhaps a horizontal tie to the cubby, not sure it'll really add much stability as the tree is so thick already
Most of the 101s seem to be American but essentially have chunky beams with slimmer joists on top: https://www.thisoldhouse.com/yards/21017559/how-to-build-a-tree-fort
Questions I've got already and would love some thoughts on!:
- The US tutorials all seem to have crazy amounts of proprietary tree bolts and brackets. Our tree is mature so I'm not anticipating huge growth, for bolting the beams and braces to the trunk what sort of lag bolts might be usable?
- Economic timber options for the beams, braces and joists
Re: How to build a treehouse?
Hi @kitfriendesq,
Sounds like a fun project. I'm sure our resident Bunnings D.I.Y. experts will be happy to assist as soon as possible to you build the treehouse safely.
Let me also tag some other members who have taken on treehouse projects: @Dan_M@mjkworldwide@Jerry1@Holdent
Check out @Dan_M's Building a treehouse discussion for some excellent techniques. And our collection of clever cubby house designs might also provide some inspiration.
kitfriendesq
Yes I saw @Dan_M's treehouse post and was very inspired!
Hello @kitfriendesq
I propose doing some measurements and drawing your framing plan on paper. From there you'll be able to see where you'll need to put the lag bolts. The store does carry some Everhang M12 x 120mm Zinc Plated Hanger Bolts, but if you are after something bigger you could use coach screws. The size of the bolts also depends on the size of the timber pieces you'll be using. I propose looking at 90 x45 H3 for your framing and 70x35 for the house walls and roofing.
kitfriendesq
Minor planning update - I’m thinking of using these poles as my core structure as they’re economic: https://www.bunnings.com.au/100mm-1-8m-pole-h4-treated-pine-round-cca-1-8m_p0123064
Current plan will be to put in 4 uprights on stirrups to reduce what I’m drilling into the tree and bespoke hardware fun, and enable me to hang my hammock underneath for nap time 😴
Sounds like a good plan @kitfriendesq
I can't wait to see a progress update.
kitfriendesq
Current draft sketch - there'll have to be a good deal of 'on site configuration' to workout the cutouts etc for the real poinciana but this was a 'not wrong' sample model in Sketchup so I went with it.
This uses the 100mm diameter poles with:
- 2.4m uprights
- 3m cross beams - I've gone with 4 front to back to give about 600mm spacing for the deck
- 1.8m whatever-you'd-call-the-front-to-back-joist-type things - I've put one either side of the trunk in my model for now but in reality I think I can nestle one in the middle to put weight on the Y of the trunk which feels desirable.
Deck is currently modelled as https://www.bunnings.com.au/90-x-22mm-decking-h3-treated-pine-2-4m_p8032583
There's been a request for a spiral staircase from the cubby upwards but I may try and encourage the 'stakeholders' to simplify this aspiration 😂
@EricL  @JacobZ  / all - would love your inputs on:
- joints to use for the poles. I was thinking of strapping originally (a la https://www.bunnings.com.au/airco-30-x-0-8mm-x-30m-structural-galvanised-strapping_p0553627 )
- best timber to use to add some diagonal bracing for the uprights to connect to the beams and joists
CleanShot 2025-01-04 at 19.34.11@2x.png CleanShot 2025-01-04 at 19.37.15@2x.png
Good Evening @kitfriendesq
Love the cubby house :smile: For some reason I thought Id seen this awhile back and commented. 😕
You have taken me back when I was a kid building treehouses and forts :smile:
Joints for the poles, I like notching and bolts. It has a solidness to it and feels more structually sound.
I like how the structure is seperate from the tree, trees move and its very hard to build something that covers both at the same time. The way you are going it gives the appearance of being in the treetops without hurting the tree and also without having to worry about the 5cm or more sway in the wind.
Are you going to have the ability to climb on the new horizonal section? Some sort of diagonal bracing is needed. You could always stay simple and use the same timber as you are for the decking. Its much more viewable and less likely to be run into by kids running around... or adults.. :smile:
I have built a privacy screen/fort and even tho I have some diagonal bracing I should have more. If you throw yourself side to side up top you can feel it move a tiny bit.
Courtyard privacy fence and gate build
Courtyard privacy fence and gate build, Part 2
Is my build for a high Privacy screen, Tho the guys at work call it a fort :smile:
kitfriendesq
Thanks @Dave-1 - definitely climbable on top, just haven't designed the walls or stairs yet 😁
Hi @kitfriendesq,
Building a tree house will be a wonderful experience for both you and your children to share, but we need to make sure it is done right. Considering it is going to be used by your children; it is absolutely paramount that safety is at the forefront of your design.
Understandably, it's unlikely that you'd contact an engineer for assistance designing this, but at that height, it's certainly something you should consider or at least use an engineer's mind to "overthink" and "overengineer". This is especially relevant because it will not be anchored to the tree, which would typically give a tree house a lot of its strength.
In saying this, the 100mm 1.8m Pole H4 Treated Pine Rounds are not structurally rated. These 90 x 90mm 2.4m F7 H4 Treated Pine Premium Posts which have a structural grade (F7) would be a better option. The pine rounds might be strong enough, but they are not specifically rated to support structures like this. Posts are not something you should take liberties with as ultimately; they are the main thing holding your tree house up.
As you are essentially building an elevated deck, you should apply the principles of deck building to ensure that it is constructed to a safe standard. Check out How to understand deck components and How to understand deck span tables for some guidance. You'll need bearers of a suitable calibre to span between the posts and joists capable of spanning between the bearers. You should also increase the number of joists as decking boards will usually recommend 450mm joist spacings.
The next thing to consider, as @Dave-1 has mentioned is lateral bracing. Generally, in deck building, this is something that would be determined by an engineer. I can't say for sure what they would propose, but knee braces made of the same material as your joists are likely a good option.
I think with a few tweaks to the design; this is going to be a safe, but incredibly rewarding and exciting project.
I'm excited to assist as much as I can moving forward.
Let me know what you think.
