How to build a raised garden bed with seating?
nvelaga
Hello experts,
I am total beginner and planning to step up my DIY journey.
I am planning to setup a raised garden bed with seating options in couple of places. Along with it i am planning to install part of my back yard with decking ( deck with will be partly on concrete slab ). I have attached my plan and the sample raised bed i am considering.
I am looking for suggestions on how should i plan the project , tools needed and procure materials ? I am finding lot of information over internet and its confusing.
Thanks in advance :smile:
nvelaga
Re: How to build a raised garden bed with seating?
thanks @JacobZ ,
if we need to use posts, does these suffice ? 100 x 100mm 2.4m Post H4 Treated Pine Sawn CCA - 2.4m , i think we need to cut them into half.
Let's say i have used, retain-it posts. Is it easy to cover those with merbu cladding ?
Hi @nvelaga,
If you need to use timber posts, anything that is H4-treated will work. The posts you have linked to are a good option, but they will not be the same colour as the sleepers. You can use a sleeper as a post, you'll just have to dig the hole wider to accommodate it.
If you use the Retain-It posts, cladding them with merbau will hide them extremely well and is a great way of doing it. There might be a very slight bulge where the merbau crosses the posts, but you can cut a shallow rebate in the back of the merbau board before attaching them to remove this bulge.
nvelaga
Thanks @JacobZ , i am thinking to use the posts inside as shown in the community project - so that posts will be inside and hidden.
Would you be able to guide me on below
1. Timber screws that are needed
2. Does 600 mm depth sufficient ?
3. Do we need to coat those posts with rubber paint ?
4. Diameter of the post hole ?
