Hi, I,m in need to build an 4x1.2 thermal platform platform for my mobility scooter. I,m 74 and limited to lifting etc. The underside of the bottom sheet needs random 40x65 feet or similar, then the same sheet requires frame work,sides of the same or similar 40x65 timber. the cavity that's ten provided I want to fill with a cheap but useful insulation, followed with the top sheet screwed down.
My issue is who do i contact to get a price to deliver these sheets of ply and small size framing delivered and set up on my tressils to enable me to start the construction.
Just contacts first please to enable me to put my ducks in a row to budget.
Cheers
Rod
Hello @Coolie74
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your platform.
I suggest writing down your materials list including the screws you'll be using and emailing it to the trade specialist of your closest store. They can prepare a quote for you that includes delivery. You can also give your local store a call and they can arrange a quote for you.
However, in regards to setting it up or building the structure, I can only suggest posting the job on Airtasker or Hipages. You can also ask family members if they know of a local builder who's willing to assemble the structure for you.
Hi Eric, thanks for allowing me to use this platform, I know need to remove it however cant find a delete, or cancel button.
Hi @Coolie74,
Hope your project is progressing well. We don't remove or delete discussions on the site as they typically have value to other members who might have the same challenge.
Thanks,
