Hi team,
Looking to tackle a DIY deck at my parents backyard.
Some details of the space:
- roughly 24m2 (7mx4m)
- Working area is concrete slabbed. Level is variable in certain parts
- Clearance from the internal space to the concrete slab is around 100mm only
- The planned deckspace is covered with an awning - still yet to decide if I'll work around the 4 posts or work right up to it
My thoughts:
- From what I can understand the internal to slab clearance available would be a ideal for 'low profile' deck
- I'm thinking of using adjustable pedestal feet that will accept the joist frame directly (no bearers). I saw that there's also pedestal feet that will accept blockers
Questions:
- Are gal nails or framing screws better?
- is there any significant feature advantage with pedestal feet that will accept blocker pieces? does it even matter?
- H3 treated wood is reccommended for above ground/outdoor use but what size timber pieces should I be considering and how far apart are the spacing between joists at their centre? I'm sure there's a best practice/building code to this question I'm not familiar with where to start looking
- How do I know the spacing requirements for the pedestal feet?
- Can anyone improve on what I'm thinking of doing or provide other ideas?
thanks in advance!
Hello @Halima
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your plan on building a deck.
Please allow me to try and answer some of your questions.
I also suggest checking the rules and regulations of your local council regarding low-level decks. There might be rules in regards to size limitations and permits.
Hi @Halima,
Let me also extend a very warm welcome to the Bunnings Workshop community. We are looking forward to seeing your deck project come to life.
In addition to Eric's helpful advice, you should find the guide How to build a low-level deck useful.
