Gap between decor screen post foot and concrete path. Seal it or not?
CarlL
Hi all,
I have secured some decor screen posts to my exposed agregate path. There is a gap between the post foot and the path because washers are used to ensure posts are plumb.
Is it a good idea to seal the gap with silicone or better off to leave it open.
Re: Gap between decor screen post foot and concrete path. Seal it or not?
Hello @CarlL
Thanks for sharing your question about your post footing. I vote leaving the gap to allow water to escape should any find its way there; it also allows air to pass through which promotes evaporation. Since you've used galvanized fittings, it should be able to withstand inclement weather.
Let me call on our experienced members @Dave-1 and @Nailbag for their vote on the matter.
Hi @CarlL
Unless it’s an eyesore for you it would be safe to leave as is. Otherwise you could run a bead of black silicone around the outside which would cosmetically have a cleaner finish. This would be more preference.
