Does the direction of skillion roof matter?
PatDIY_Dad
Building a Reputation
More or a.info question then a how to do question about skillion roofed firewood storage
I just finished building one out of pallets I got for free and spare hardwood boards I had. The only thing I did differently which wasn't intentional was the angle of the roof is lower at the front
Would this be any disadvantage vs water running off from the back ? I noticed most videos of this design have the water running down at the back instead
I want to have my storage sitting against a shed wall
If its a big deal I'll.change it but if not I'll leave it
Picture attached is the one I made
YouTube link is one of the videos I'm talking about
https://youtu.be/8QbSYn-rtVk?si=TzXTR8IYzJbfdh5J
Re: question of direction of skillion roof for firewood storage
Hi @PatDIY_Dad,
Thank you for sharing the photo of your firewood storage, it looks great.
Considering you are planning to have it up against a shed wall, my first thought was that you would want the water to run away from it, which it would in the current orientation.
Ultimately the orientation of the roof wouldn't have too much of an effect, but it should not negatively affect the existing shed, which could happen if you are directing water towards it, so I'd keep it as it is.
Let me tag some of our helpful members to see if they have any thoughts, @Dave-1, @DIYGnome, @TedBear.
TedBear
Hi @PatDIY_Dad ,
The only disadvantage that I can imagine is that the flow of water off the roof toward the front may blow in and wet your stored wood.  The solution to that would be to add a gutter along the front of the roof to take the water to the side.
PatDIY_Dad
Thanks I'm just going to leave it
PatDIY_Dad
No worries
It will be negligible. Probably get more wind blowing rain through the gapes because of the position I plan to put it in
Afternoon @PatDIY_Dad
:smile: late to the party and its solved lol I like @TedBear's suggestion of a gutter as well.
Nice build btw :smile:
PatDIY_Dad
I've finished making it but had a last minute idea to make the wood last longer outside would it be worth painting it with some kind of decking oil
The firewood that will be stored in there will be used for cooking in my pizza oven so don't want anything that can contaminate the firewood
Morning @PatDIY_Dad
Id definently go with some decking oil to give it a longer same colour life. Once dry I dont see any oil being transfered to anything else. Ive scooted around my deck building things on it and never have oil transfer to my clothes as an example.
There are some more green type oils but they dont last as long. Id go fulls trength as you have used recyled pallets :smile:
PatDIY_Dad
There goes the idea of not spending any money and just using stuff I had already around the house 🤣
Paints and decking oils aint cheap
Noyade
I made a floor 'carpet' under outdoor covered areas using pallets that kept things like a cement mixer, air compressor and so forth off the ground.
Within two years I discovered the pallets were full of termites. I guess wood, moisture and earth = woodeaters?
"Wood" the traditional pallet be treated for termites?
