Cracks in weathered fence
vica
Having an Impact
Good day ! My fence is weathered. I am considering to fill cracks and then Sand ,at last paint. Can I use wood hardener first and fill? By the way ,the fence is white now , can I directly paint with Walpamur 4L Jarrah Fence Finish?
Vica
Re: Cracks in weathered fence
Hi @vica,
The Earl's wood hardener is a versatile product that can be filled over, sanded and painted after it has hardened the timber. This product can be used on a fence that has rotted and I have added a video below of the process. You can certainly paint your white fence with Walpamur 4L Jarrah Fence Finish, I would get enough to do two coats to cover the white as from memory I believe that paint is fairly translucent.
Please let me know if you have any additional question or need assistance.
@MitchellMc . Thank you so much You are so kind! I have painted Earl’s wood hardener in fence .It looks work . Some deepest corners can’t be painted . Maybe I need a special small brush ?
Vica
@vica,
I'm glad to hear the Earl's wood hardener was effective on the fence.
A small paintbrush will certainly assist you in getting those hard to reach places. If you can take a picture of the areas you are finding hard to paint I might be able to recommend a specific product for you.
@MitchellMc It is so appreciated of you  ! Like this wood . It needs wood hardener . But it is near the corner of two walls.my brush can’t touch its inside .  Vica
@vica,
The perfect brush is a Monarch Bevel Paint Brush which has an angled handle on it to reach behind your posts easily. If you have a look at Monarch 12mm ABC Synthetic Bevel Liner Paint Brush you see a video which shows the features of this brush.
You could also use a small roller like the Uni-pro 100mm You Can Do It Gloss And Low Sheen Mini Roller Kit.
