Can you use Lytworx 10m RGB And White LED Strip Light with another transformer?
Kissnaxn
Hi team,
Regarding Lytworx 10m RGB And White LED Strip Light 24v , can I connect it with other third party transformer 24V 200w  ? As I have others lights too in garden and seems lot of transformer . Hence planning to connect all of my outdoor garden lights to one transformer.
Re: Lytworx 10m RGB And White LED Strip Light 24 V
Hi @Kissnaxn,
Thank you for your question about the Lytworx 10m RGB and White LED Strip Light 24V. While it's understandable to want to simplify your setup by connecting multiple lights to a single transformer, we cannot recommend third-party power supplies for use with our products.
To ensure optimal performance and safety, it's best to use the transformer that is specifically designed for the Lytworx LED strip lights. If you're considering integrating multiple lights into one system, I recommend checking the specifications of both the LED strip and the transformer to ensure compatibility and seeking the assistance of an electrician to perform the connections.
Thank you for a reply. What about two 10m light strip to just one controller and transformer ? Does it work or led will ne dimmed due to low power?
Hello @Kissnaxn
I don't recommend mixing and matching transformers or using two electrical items into a single power source. It's best to use the transformers provided in the LED kit.
Let me call on our experienced members @JoeAzza and @Nailbag asking them their for their recommendations.
Hi @Kissnaxn
without knowing the specs of both the LED light strips and the transformer its not possible to advise on compatibility to combine the two. So, my suggestion would be to contact the tech support for Lyworx to get a definitive answer. This appears to only be via their Facebook page.
Regards, Nailbag
