Hi All,
well after binge-watching just about every episode of 'Treehouse Masters', buying the book, and also scouring Youtube for related video; I've been bitten by the treehouse bug !....
I'm lucky to have a block that is not only blessed with 2 x giant Tuart trees; but also a few others in a bit of a group down the back; away from neighbours, so time to get started !! I chose the rear grove of trees as it's a bit more private; and sidn't want to mess with the big ones.
If anyone wants to get the bug - check out treehouse masters on foxtel; or look at nelsontreehouse.com online
construction will be a platfrorm about 2.5m off the ground, half deck, half enclosed 'cubby'
here's a quick sketch plan and the trees as an idea - it will no doubt evolve as the buid gets underway.....
trimmed off the overhang, and it's looking pretty good - will get a tin of 'mission brown' to re-coat deck + patched holes
now for the (form) ply flooring to go under cubby part. 19mm film ply. A chalk line was perfect for tracing where beams were underneath !
Hi @Dan_M,
I have really enjoyed your treehouse updates and am sure that the rest of the Workshop community has too!
Have you got back into it after the Easter break?
It would be fantastic to see some more updates soon.
Thanks again for sharing this wonderful project.
Where did you get the high tensile rod from?
Thanks for joining in the discussion @Matt_C. Let me tag @Dan_M for you so he is alerted to your question about where to obtain the high tensile rods.
Welcome to the Workshop community. We're sure you'll get loads of helpful information, advice and inspiration for all your projects around the home and garden from our wonderful members. Please don't hesitate to post anytime you need a hand or have something to share. We'd love to learn more about your projects and plans.
Hi @Matt_C,
I got it from a mob in WA called WA fasteners - I got 2 x 900mm lengths which I recall were about $50 each. they're M25 I think.
I cut each in half (450mm) and sunk each about 25cm into trunk.
I'll have to post some update pics of build progress - nearly finished
Hello @Dan_M
I can already see that big smile from your child's face she is going to love this! I would love to put up a tree house but alas there are no big ones in my backyard. Looking forward to the finished product! Fantastic build!
Red
well, been a while.... I had a hard year last year.... - won't go into it
anyway, a few comments has revealed a bit of interest in the build, so I'll throw up some updated pics
next was railings
Next - the cabin !!
I was lucky enough to score some composite panel from a local wholesaler who had some lengths of 40mm thick sandwiched foam with steel skin. they are interlocking panels used for sectional garage doors (great idea to have insulated garage roller door !- check out http://tigerbuildingsystems.com.au/ ) They had some panels that were water damaged and couldn't be sold for normal use, so I got them very cheap ! - they even cut it to length for me
plan was to mount it inside some sectional 'C' Aluminium channel....which would've been perfect....except there was no 40mm channel.... so I had to get 50mmx25mm.... got from Ulrich aluminium - who also cut to size https://www.ullrich.com.au/
To make 40mm panels fit into 50mm channels....took a bit of thinking; but I discovered that DIY lengths of Flyscreen panel frame are a perfect 25mmx10mm, nice and light, and pretty cheap. This would be used to 'pack' in the panel so it was snug - worked perfectly, very neat, and left no nooks for spiders/nasties to set up camp....
C-channel was screwed to base and through into beams below. composite panels were glued and riveted into channel; and very cool 90o channel joins used for corners, and also for attaching roof later on
gap left for door, and then onto roof ! - closing in the final panel was tricky....but it's all done and solid as a bunker !!
