Hi our pavers have started to lose the grouting between them and when we did a section using M3 mortar from Bunnings the colour was inconsistent. The next section is in a prominent position so we are reluctant to use the same product. The pavers have an 8mm+ gap between them. What product would you suggest and what process would you use ?
Hello @Susiegot
Sometimes depth is a factor, but it's not a fixed rule. Patching new with old or in-between gaps produces exactly the type of issue your facing. Using another product might give you a closer match but it will never match your current grout as it has been weathered. You might have to remove all the grout and start fresh. This will at least give you uniformity on the first go. The undetermined part is that even if we used a different product there is no guarantee that you would not run in to the same issue. Old and new grout sometimes just don't work well together. I recommend trying one of our suggestions and try to brush clean the grout line with detergent or tile and brick cleaner. I know it's tedious but it's one of things you can try short of full re-grouting. Good luck and stay safe.
Red
