Hello,
I have two wisteria vines that are currently climbing up two metal beams (square cross-section, roughly 7cm in diameter, about 3 meters apart). I'd like to the connect the two metal beams with a piece of wire/string so that the vines can connect horizontally (and eventually create a semi-feature).
What would be be the best way to string the two posts together to allow this? I've attached a rough diagram to illustrate.
Thank you
Hi @bluebottled,
I'd suggest installing some eyebolts through both of the metal posts. An alternative would be wire eye straps that you could screw directly into the posts. You can then run either stainless steel wire or braided cable between them. If you're going to use the braided cable, I recommend picking up a couple of wire grips and a tensioner to assist with installation. Using the wire rope would give a more premium look, but if you'd prefer function over looks, the wire rope will work fine. I've created the below renderings to illustrate.
Hi Mitchell,
Thank you for the detailed response and apologies for the late reply.
Ideally I'd like to avoid drilling a hole into the poles, would there be any alternate options to stringing the wire? Would using a U bolt or tensioning the wire (so that it tightly grips the pole) be options?
Many thanks,
Hi @bluebottled,
No need to apologise.
You could simply just wrap a stainless steel wire around the post and twist it around itself with a Whites Fencer's Tool. The same can be done on the other post to tension the line. This method has been working fine for farmers for the past hundred years.
Hi, this is how I did a similar project at my place, using what Mitchell suggested but with turnbuckles to improve on the wire tension or to remove it if needed. I also added galvanised caps to improve the posts life by avoiding water soaking through the end. Ciao
