Hi @Gordon937,
Thank you for your question.
It is an isolation valve on either a gas or plumbing line. It is used to turn off the flow of gas or water so maintenance work can be done.
Was there a particular reason that you asked?
Thanks Jacob for some reason the hole is attracting bees.
Hi @Gordon937,
Is there any kind of smell around the isolation valve? There is oftentimes a sweet-smelling additive put in natural gas so gas leaks can be noticed. It's possible that if there is a gas leak, the bees are attracted to this smell. If you can smell gas or hear a leak, I'd suggest contacting a plumber with a gas fitting licence immediately.
It could also be something as simple as it is a protected area that the bees have found shelter in.
As pollinators, bees are super important to our ecosystem so if they are becoming an issue, I'd suggest contacting a beekeeper in your area who I'm positive would be happy to help out by safely relocating the bees.
Let me know what you think.
Thanks Jacob
Am passing your info to my daughter who has the problem. Apparently they contacted a bee man who sprayed but these scout bees have returned.
No worries @Gordon937.
Hopefully, there isn't a leak, but your daughter should definitely prioritise investigating this.
