tv wall bracket to use for 75 inch tv
geoffey
Community Newcomer
could i use this to mount my 75 inch tv to the wall.my tv weighs 31kg this bracket is rated for 40kg?
https://www.bunnings.com.au/click-tv-wall-mount-with-tilt-and-swivel_p4360466
Noyade
Re: tv wall bracket to use for 75 inch tv
G'day @geoffey
Looking at the specs  - weight says yes - but no to the screen dimension.
But scrolling though the reviews, we find Kama M. However, they are not extending (435mm) the screen from the wall.
The negative reviews all appear to be about it not being designed around 600mm stud spacing.
That can be solved.
Cheers.
Hi @geoffey,
While it may be fine, I'd advise against it as the product manufacturer tests and certifies their products based on the dimensions they've provided. If anything were to go wrong, you would not be covered by their warranty as it is being used outside of the advised specs.
If you'd like to mount your 75-inch TV, you would be better off using this Practa 37 - 85" Variable Height Fixed TV Wall Mount PRWMFL or this SANUS 42"-90" Full Motion TV Wall Mount Bracket.
geoffey
Community Newcomer
im unsure of wall studs in my house,(older style house) i've used a stud finder but there pretty hit and miss?
would i need a space board on wall to mount this bracket better?
Noyade
Afternoon @geoffey
"(older style house)"
I too have an old house, in some rooms I have a layer of fibro with two covering layers of gyprock. The electronic stud-finders I've tried are useless.
But I have had 100% success in locating screws/nails in the studs with rare earth magnets and measuring the 600mm once located. Sometimes there is a screw/nail located at every 600mm distance.
You will still need to locate the studs for your "space board."
Currently only $14.80 at Bunnings.
Worth a try?
https://www.bunnings.com.au/trojan-magnetic-stud-finder_p0673723
geoffey
Community Newcomer
thanks for the info,what isle is this in as ill go there today
