Punched a hole into the pipe running down for the garden tap outside. It's fixed however I want to render and repaint.
The max hole depth is about 55 mm. Would I need some small reinforcement mesh /structure to hold the rapid set mortar repair (Either Lanco 136 or Dunlop Premix)?
Please suggest the best way to DIY.
Hi @hmt23,
I'd suggest using Sika MonoTop-352NFG Structural Repair Mortar as it can be applied up to 75mm thick without any additional reinforcement.
I'd suggest starting by cleaning the concrete around the pipe with a wire brush to remove any loose material and clean the surface.
The pipe should also be wrapped with foam such as ableflex to allow for expansion and contraction of the repair mortar around the pipe. This will help prevent the pipe cracking in the future and is always good practice when possible.
You can then use the Sika MonoTop®-352 NFG product datasheet for mixing and application instructions.
Let me know if you have any further questions or need some clarification.
Thank you mate. Appreciate timely response.
