How to install curtains without drilling?
Tanya75
Any ideas on how to put up curtains up on metal door frame without drilling? brick overhead. was thinking to do big 3M hooks and get a small rod but my door is 245cm long and the frame width where i would stick it is only 4cm wide and big 3M
sturdy hooks are 5cm
Re: Wanting to put curtains up without drilling. Metal doors, brick house
Welcome to the Bunnings Workshop community @Tanya75. It's terrific to have you join us, and many thanks for your question about hanging curtains.
What style curtains and rod were you thinking of? I suspect that if you are not mounting into the brick, you'd be limited to shear and very lightweight curtains. Even when mounted onto a solid surface like plasterboard, with appropriate fixings, curtains have a tendency to pull off the wall.
Is there any reason why you don't want to fix into the bricks? Perhaps this is a rental?
You could try one of these Windoware 130 - 244cm White Springfit Rods, though it might need to be packed out slightly as it is 10mm too short. As mentioned, though, it is only designed for lightweight curtains.
