How to stop window condensation?
Thierry
Building a Reputation
Hi
During the cold season my huge window glasses have condensation issues in the rooms.
Water is dripping and can cause molding issues on the wood.
Just wondering if there's any sealant or advice to address these issues
Thierry
Noyade
Re: window condensation issue
Afternoon Thierry.
You got me running to my windows!
Mine are very old aluminium windows - but there is a channel that catches dripping condensation and releases it outside through small holes.
I know I have had your problem above - but it was due to the outlet holes being clogged up. Once un-clogged, problem solved.
But I can't quite make out the channel system in your photo above?
(PS - I am not a glazier. I have limited knowledge with windows)
Re: How to stop window condensation?
Hello @Thierry
Thanks for sharing your question about condensation on your windows. I suggest having a quick look at this discussion - Condensation issue: My windows are swimming in winter. by @DCS. One of the main causes of condensation on your windows and in your house is trapped moisture and lack of air movement. If you're currently using an unflued LPG heater it produces a lot of carbon dioxide that mixes with the water vapour in the air and that produces condensation.
I recommend providing a point of exit for the air and moisture that's present in the room. Keep the doors open and perhaps leave a window slightly open to allow air to circulate.
Thierry
Afternoon Noyade
Sorry for late reply.
I dont notice any channel on my windows. The brand is all weather windows.
There's only one part of window which is leaking . I plan to tape the edge of the window glass and frame.
Thierry
Hi Eric
Sorry for late response.
There's no heater in the bedrooms. When showering and cooking , i close the doors.
Only 1 window frame is leaking in my bedroom.. i plan to tape the edge of window glass and frame.. hope this prevent air from outside to come inside.
Hello @Thierry
That's perfectly alright, is there no drain hole near your window or on the aluminium itself? As @Noyade suggested, have a look around and see if the drain hole is plugged up. Taping up the window will not really solve the condensation issue. I suggest instead keeping a door open so that there will be constant airflow in the room. Only when the air stops moving will the condensation start forming.
Remarka6le
I Agree with @EricL @& @Noyade ,
Try and find a weep hole if you can, if you do, see if it's blocked up and clean it out with a small flexible brush. Is the water from the middle frame dripping into the bottom channel and overflowing or is it missing entirely and hitting the wood directly?
Remarka6le
Thierry
Thanks guys.
I just noticed the drain hole which is in the middle but bottom one has no drain hole.
I wil try to clean this. Hopefully will work. Cheers
