How to replace sliding door rollers?
johnpostle
I am just replacing the rollers on this cavity hidden sliding door I have the correct rollers R4400 but not sure on the procedure
Re: How to replace sliding door rollers?
Welcome to the Bunnings Workshop community @johnpostle. It's sensational to have you join us, and many thanks for your question about replacing rollers on a sliding door.
Where are you up to at the moment? Have you been able to remove the sliding door from the cavity?
If you take a look at the video I've added below, it will give you a good idea of how your door might be installed. Typically, a locking mechanism attaches the mount on the door top to the rollers. Once the door is detached via its mechanism, you can remove the rollers from the track. If you can take a picture of the mechanism, our helpful members should be able to advise on how to unlock it. Let me know if you need a hand uploading images.
