Can I attach a ply wood ceiling onto a steel framed house?
Welcome to the Bunnings Workshop community @Sandy13. It's great to have you join us, and many thanks for your question about attaching plywood to a steel frame.
The simple answer to your question is that plywood can be attached to a steel-framed ceiling. However, you might like to provide a few more details on your project so our helpful members have a better idea of what you'd like to achieve. If you can provide some images of the ceiling in question, that would also assist; let me know if you need a hand uploading them.
For attaching the plywood to the steel frame, you could use self-tapping metal screws. You'll then need to decide whether you'd like to fill over the screw heads.
Hi Mitchell. We are looking to put marine ply onto a vaulted ceiling with a black edging to shadow it if that is what is called. We are in the process of building a PAAL kit home a small home and thought ply look would give it some point if difference. Any more tips would be greatly appreciated Cheers Sandy13
That sounds like a wonderful project and will certainly make a difference to your home @Sandy13.
I presume you would like to create this look from scratch. Often these plywood/Shadowline ceilings are a proprietary system that includes a connecting tongue for the sheets. If you were to attempt creating this system yourself, you might go about it by adding a rebate channel to the edge of the sheets with a CRAFTMASTER 4mm Slot Cut With Ball Bearing 6.4mm Shaft Trade Quality Router Bit and then inserting a prepainted length of Metal Mate 50 x 3mm 3m Aluminium Flat Bar as the joiner. The flat bar's width can be adjusted to suit your desired shadowline width.
