How to remove paint from a brick fireplace?
akg92
Hi there,
I’m looking for tips on how to remove paint from a brick fireplace - I don’t want a clean finish, happy for it to be a “white wash” type look after.
Please see picture of painted fireplace & then see inspiration pic of whit wash fireplace (how I’d like it to look).
thanks so much!
Re: removing paint from a brick fireplace
Hello @akg92
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your fireplace.
Is your fireplace a functioning fireplace or is it just for show? Would it be possible for you to post a picture of the current fireplace? If it is currently painted, you'll need to identify what kind of paint was used on the surface.
If you rub the painted surface with a clean rag dipped in methylated spirits it will either remove the paint which means that it is water-based, or it goes shiny which indicates that it is oil based. Once you identify the paint you'll need to sand and clean the surface before you apply a primer to it
If your fireplace has been decommissioned and is no longer functioning, I suggest using Dulux 1Step Prep Primer, Sealer & Undercoat 4L if it is painted with a water-based paint. It is a multi-surface undercoat that can go on brick or masonry surfaces as well. For the topcoat, I recommend Dulux 4L Vivid White Low Sheen Wash&Wear +PLUS Anti-Scuff Interior Paint.
However, if it is still a working fireplace, I suggest speaking to a fireplace specialist as any paint used on its surface must be heat rated. Ordinary paint will not work on a working fireplace.
akg92
Hi Eric,
thanks for your reply.
Apologies, my fireplace is the painted white one with the flower picture leaning on it - I’m wanting to strip that paint back and make it look more like the second picture ☺️
the fireplace isnt working and is just for show ☺️
Hi @akg92,
I'd suggest using Tricleanium Paint Stripper alongside a Trojan 6 In1 Multi Paint Scraper to remove the bulk of the paint.
Due to their porous nature, a small amount of paint will likely have penetrated the bricks. Unfortunately, the stripper would not be able to remove paint that is inside the pores of the brick. As you've indicated you don't want a perfectly clean look, this look might appeal to you.
Make sure you follow the manufacturer's instructions for use, open windows and doors to allow ventilation and wear all appropriate personal protective equipment including a mask/respirator, gloves, eye protection, a long-sleeved shirt and long pants.
Let me know if you have any questions.
Hi @akg92,
I thought I'd add to @JacobZ's advice by recommending that you try a wire brush or wheel, for the paint removal. It's likely best to use it in combination with the paint stripper he's suggested. Ensure you lay some drop sheets to protect the surrounding surfaces.
