Any ideas how I could make something like this with an extra cube/column to better fit our space?
Hi @TrooperJo
Are you after a cabinet for the bottom of your TV? You can assemble a similar looking one using the Flexi Storage Clever Cube Oak 1 x 4 Storage Unit. In order to raise it height, I suggest using Adoored Black Steel Angled Corner Furniture Leg. To give it a proper top, I recommend using a Specrite 2200 x 600 x 26mm Timber Multi Use Pine Panel.
However, if you wish to copy the exact layout of the cabinet, you can use inBuilt 16 x 1800 x 595mm Natural Wood Edged 1 Long Side Pre Finished Melamine Shelving. Another material you can use is 16mm MDF, but you will need to add a front edge of 42x19 timber moulding in order for it to look like thick timber edging. You can then paint it in whatever colour you want.
