How to install floating floor over hardwood?
Yuggle
Hi. I'm installing a floating floor over hardwood flooring (there is reasonable sound-proofing under the floor between the joists) and have purchased Bunnings "Smart Home Products 9.5mm 2.887m2 Soundguard Acoustic Laminate Planks - Camomile". I've also purchased Bunnings "Qep 2mm Ixpe Acoustic Pro Underlay" and several sheets of 6mm villaboard. All up, the 17.5mm is within my 18mm limit for height of the new flooring, and the 2mm underlay is within the requirements of the planks' warranty. My issue is, I'm unsure of whether to install the villaboard first or the underlay first. I'm inclined to install the villaboard first, securely attaching it (not floating) to the wooden floor (the wooden floor is in reasonably good nick, and reasonably flat) siliconing all joins and edges creating a very flat sound barrier. Then install the 2mm underlay then the planks (keeping the sound absorptive layers together). Alternatively, I could install the underlay first, then float the villaboard on the underlay, again siliconing all joins and edges, then the planks. Any thoughts most welcome.
Re: floating floor sequence of layers
Hello @Yuggle
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your floating flooring.
The common sequence when installing floating floor systems is to install the underlay first then the floating floor over it. The underlay provides a cushion for the floating floor preventing it from rubbing against the flooring substrate and creating a squeaking noise when walked on. It also allows the floating floor to expand and retract smoothly during temperature changes. In regards to your own project, I suggest installing the villaboard first to provide a solid base for the floating floor. Installing the underlay first will negate its effectivity as the weight of the villaboard and the floating floor will flatten it.
Many thanks Eric. As regards the villaboard, , nailed, screwed, glued or some combination? As mentioned, I intend silicon'ing all joins and edges to create a sound-blocking layer.
Hi @Yuggle
I recently replaced my slate flooring and used Selleys 350g Heavy Duty Liquid Nails to glue my yellow tounge on the floor. I recommend screwing the panels in place as they provide a more stable grip. I propose drilling pilot holes to prevent snapping the screw heads off. I recommend using Kango 19 Piece Cobalt Drill Bit Set on your hardwood flooring as ordinary drill bits can't cope with the stress of drilling into old hardwood.
My best advice is to invest in real good drill bits and to use Kango Hypertorque 89mm PH2 Impact Driver Bit to prevent stripping the tips.
Please make sure to wear personal protection such as gloves, goggles and a mask.
Good Evening @Yuggle
I have the same thoughts as into the layering of materials that @EricL has. It makes sense to fix the villaboard first before the other layers are placed on top.
I prefer a torqued driver for screwing into hardwood. I have had better experince using my Ozito torqued driver over my ozito impact driver (yes the ozito dosnt have fine control so that could be the issue) I was snapping the decking screws going through hardwood planks and then into old recyled hardwood posts. I would have a try and then modify the install if needed.
Re: How to install floating floor over hardwood?
Hi @Yuggle
Definitely the Villaboard then the acoustic underlay. This should be nailed as marked by the fixture dots in the top layer of the board with suitable brads,which is a standard method for tile underlay
