Any ideas on how to put up curtains up on metal door frame without drilling? brick overhead. was thinking to do big 3M hooks and get a small rod but my door is 245cm long and the frame width where i would stick it is only 4cm wide and big 3M
sturdy hooks are 5cm
Welcome to the Bunnings Workshop community @Tanya75. It's terrific to have you join us, and many thanks for your question about hanging curtains.
What style curtains and rod were you thinking of? I suspect that if you are not mounting into the brick, you'd be limited to shear and very lightweight curtains. Even when mounted onto a solid surface like plasterboard, with appropriate fixings, curtains have a tendency to pull off the wall.
Is there any reason why you don't want to fix into the bricks? Perhaps this is a rental?
You could try one of these Windoware 130 - 244cm White Springfit Rods, though it might need to be packed out slightly as it is 10mm too short. As mentioned, though, it is only designed for lightweight curtains.
