How to install an 1800mm long shelf using Flexi Storage?
boschbird
Hi, I have bought a Flexi Storage shelving solution using the Customer Home Storage System (CHSS). I noticed that even though the CHSS allowed me too, I don't think I can line up a 1200mm and 600mm shelf side by side to make a combined 1800mm shelf. This is because there is not enough space on each bracket to support both shelves side by side, plus you are supposed to drill the shelves in. Do you have a solution for this, or will I need to return?
Btw here are the dimensions and the items given by the CHSS.
H: 1206mm W: 1800mm 😧 😧 270mm
1 x Hang Track White 1800mm I/N: 2660962
3 x Hang Track Cover White 559mm I/N: 2660980
4 x Double Slot Wall Strip White 1206mm I/N: 2660949
3 x Shelf White 1200x250x16mm I/N: 2710157
3 x Shelf White 600x250x16mm I/N: 2710150
18 x Double Slot Bracket White 220mm I/N: 2583645
2 x Shelf Fixing Screws 30PK I/N: 2580206
2 x Masonry and Timber Plugs & Screws 35mm 20PK I/N: 2610016
 The design code is Db8A03lw if that helps.
Re: How to install an 1800mm long shelf using Flexi Storage?
Welcome to the Bunnings Workshop community @boschbird. It's sensational to have you join us, and many thanks for your question about Flexi-storage solutions.
I'm so sorry, but I've noticed that the software is not adding the Flexi Storage Home Solutions Duo Shelf Clips - 6 Pack to your design summary. These are the required clips to have two shelves on one bracket. I've passed the feedback on to Flexi-storage so they can look into correcting this issue.
