How to fix a window?
alana2286
 I have moved in to see this in the bedroom - is this easily replaced? Can I fix this myself?
Re: window needs fixing
Hi @alana2286,
From the image I'm not entirely sure what is going on here. Is the window missing a fitting that would be used to hold it shut? If so, installing one shouldn't be too much of an issue. If you can take an image from slightly further back showing the whole window and then some more with the window closed if possible, I'm sure we'll be able to come up with some solutions and window locks that would suit.
I can’t show the window closed because I can’t close it at the moment it’s being held by duct tape.
