How to enclose the walls on my veranda?
mklein90
Hi, I'm wanting to turn a section of my deck/veranda into a bit of an entertaining area/sports bar this section is undercover and already has the framework done.
The other end of the deck is open so there will be more moisture getting in compared to inside the house so I'm unsure if I can use ordinary drywall or if Ill need something specific, photos attached
Re: What can I use to enclose the walls on my veranda
Hi @mklein90,
If you want to use plasterboard, you'll need to use Aquachek which has a treated core, face and back, making it resistant to moisture and humidity without compromising integrity.
You should also consider insulating the cavity to help reduce condensation buildup. You can use Foilboard, following the Shed Installation Guide to insulate the cavity.
New Zealand readers - Please note that foil-based insulation products are banned in New Zealand.
Thanks Jacob I'll suss it out and see how I go
