How to create built-in bar fridge?
Jersey1975
 please could someone help me learn how to build this fridge in? I have built the cupboards in but not sure on the fridge. I’d like it all to look built in thank you
Re: built in bar fridge
Hi @Jersey1975,
To build in your bar fridge, you have a couple of options depending on how you want the final look to turn out. One simple way is to purchase or build a custom base cabinet for the fridge. You could leave the door off the cabinet and then add trim around the perimeter of the fridge to cover the gaps and give it a built-in look. This option can help integrate the fridge seamlessly into the surrounding cabinetry.
Alternatively, you could build a frame and plinth to elevate the fridge slightly. This will allow you to match the height of the fridge with the other base cabinets and create a consistent look across the space. By framing the fridge and adding trim around it, you can ensure the appliance blends in well and looks like a permanent part of the cabinetry.
The biggest aesthetic improvement will come from elevating the fridge with a plinth, as this will allow you to incorporate a kick panel at the bottom, making it look more integrated with the surrounding cupboards. You can finish off the look with trim to hide any remaining gaps.
Jersey1975
Re: How to create built-in bar fridge?
Thank you
how would I go about building a frame? A plinth I’m ok with but not a frame
