How to build freestanding walls for hanging pictures?
LeahBlacker
Hello,
I need to buy or make 4 x freestanding double sided walls for hanging and display of picture frames for our small exhibition space.
Approximate dimensions would be 1200mm wide by 1800mm high.
Can anyone get me started with the materials required and instructions to successfully complete this project.
Thank you,
Leah
Re: How to build freestanding walls for hanging pictures?
Hello @LeahBlacker
Thank you for sharing your question about how to build free-standing walls for hanging pictures. I've placed a suggested plan below for you to have a look at. If you have any questions about its assembly please let me know.
Tools needed:
  • Circular saw
  • Cordless Drill
  • Assorted Drill bits and screw bit
  • Measuring tape and pencil
  • Builders square ruler.
Materials:
LeahBlacker picture frame1.jpgLeahBlacker picture frame2.jpgLeahBlacker picture frame3.jpgLeahBlacker picture frame4.jpgLeahBlacker picture frame5.jpgLeahBlacker picture frame6.jpgLeahBlacker picture frame7.jpgLeahBlacker picture frame8.jpg
LeahBlacker
Hi Eric,
Thank you so much for your reply, it is very helpful and much appreciated.
Kind regards
Leah
Hi @LeahBlacker
I'm glad my suggestions helped. Please keep us updated with your progress, we look forward to seeing your pictures on display.
Thoo
Thanks Eric,
This post has been helpful for me as well to get started.
I am planning on a smaller unit, with the display board being oriented in the landscape position and measuring 1200 x 600mm.
What would be the dimensions required of the foot frames, to ensure it is stable?
Hello @Thoo
Thanks for sharing your question about free standing wall. I suggest staying with the recommended foot size which is 500mm. The only reason you would make it bigger is if the item you are hanging on it is much heavier. But the consequence of that would also involve modifying the frame itself in order for it to carry the heavier load.
Thoo
Thanks Eric,
How about making the foot size smaller ? For a smaller display frame
Hello @Thoo
I recommend not making the foot smaller than 400mm to prevent the panel from tipping over.
