How to build bed storage platform?
pheened21
Hello!
I have a small space and have been wanting to lift my double bed of the ground and add some storage. I have 0 experience with building or anything handy and really need some advice : )
Re: How to build bed storage platform?
Hello @pheened21,
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thank you for sharing your question about building a bed storage platform.
It is a fantastic project to be undertaking, but I'm afraid it will require you to have some experience when handling wood working tools. Your project has a medium level of complexity and when divided into separate parts is actually about two activities in one.
For example, the bed frame will need to be built unless of course your current double bed can be adapted for your needs. You'll need to build a cabinet base under the bed where you'll put your clothing and shoes. There are many examples online, it all depends on how complex you want to make it.
I encourage you to explore our How-To section, where you'll discover a wide range of fantastic projects accompanied by step-by-step instructions to assist you. Additionally, I recommend checking out our guide on Essential hand tools for beginners in DIY. This resource will help you gather the fundamental tools required to embark on your building journey.
One of the most effective ways to gain experience is by attempting to build something on your own. Even a simple DIY plant stand can serve as an excellent starting point. This project can be assembled without the need for power tools and doesn't require an extensive number of materials. By undertaking this basic project, you'll familiarise yourself with the fundamental concepts and skills needed to tackle larger endeavours.
Would it be possible for you to post a photo of the area where you are planning to build the bed storage platform? This will let our members assess the area. We can then make recommendations on how you can maximise the space for your storage platform.
I also suggest having a look at these handy links:
