How to build a canvas frame with height 84cm and width 1340cm?
mamathar
Hi There,
I need to build a Canvas with Height = 84 cm and width as 1340 cm to stretch a canvas.
Can you please help me with what light wood would be better to build the frame  and the pins I need for stretching canvas
Thanks,
Mamatha
Re: How to build a canvas frame with height 84cm and width 1340cm?
Hi @mamathar,
I am assuming you have made a typo with your dimensions, and they are supposed to be 84x134cm. Is that correct?
If this is not a typo and the canvas needs to be 13.4m wide, then I'd suggest this is something you should contact a frame maker for assistance with.
I'd suggest you use dressed-all-round Pine such as this Porta 30 x 30mm 2.4m DAR Square General Purpose Pine. This will give your frame some good strength while still being reasonably light.
You can then use upholstery pins to fix your canvas in place and stretch it over the frame.
Thank you Jacob 😊
