How to attach wall bars to a brick wall?
sandeeprmohanty
How do i attach one of these to the wall
Noyade
Re: Attach wall bars to the wall
Morning @sandeeprmohanty
What sort of wall do you have? Brick or gyprock/studs?
(Amazingly and coincidentally, this may be a product @Kingleviathan might be interested in?)
https://www.workshop.bunnings.com.au/t5/Living-and-Bedroom/How-to-attach-a-pull-up-bar-to-the-wall/t...
Kingleviathan
Cultivating a Following
I have brick
What pruduct? The takes me to the forum?
Noyade
"What product?"
The concept above - I added something similar to your thread....
Hi @sandeeprmohanty,
A warm welcome to the Bunnings Workshop community, it is wonderful to have you with us.
The manufacturer of your product will have an installation guide that should be followed. This will ensure their product is installed in a safe and warrantable fashion.
I imagine they will call for you to use masonry anchors of a suitable size through the angle brackets on the uprights.
Check out How to hang just about anything for some further guidance.
It has studs inside the wall. Not sure what the outside material is. Have attached a photo for reference
So the wall is not a brick wall but a timber-framed wall covered with plasterboard? If that's the case, you'd need to reference the installation guidelines for a timber stud wall. If the instructions only reference a brick wall, you'd need to speak with the manufacturer about whether the unit can be attached to that type of wall. The manufacturer is the best source of information for their product.
