Hamptons-inspired dog ramp
Alicia_Woodwork
Having an Impact
My gorgeous Goldie, Charlie, was recently diagnosed with hip displacia. This condition makes ordinarily simple movements incredibly difficult. It is for this reason that I decided to build a ramp to allow her easy access to some cuddles on the bed. I worked hard to match the bed frame and decor in the room with bright whites and paneling to finish.
Materials
Tools
Ryobi Drill
AEG Drop Saw
Ryobi Disc Sander
Steps
Step 1
Build the frame using 35x70mm untreated pine. If adding shelving or draws, ensure this is calculated in the frame build. Secure the frame with 75mm 10G Timber Screws.
Step 2
Carefully cut pine cladding to size and secure using 30mm 8G timber screws. Be sure to counter sink screws using a larger drill bit.
Step 3
Using 3mm coated MDF board, measure and cut shelving lining. Secure in place using indoor wood glue and 20mm 8G screws.
Step 4
Measure and cut the 9mm MDF top. Secure using countersunk 50mm 10G timber screws. Patch all screw holes and imperfections.
Step 5
Use white gap filler to seal the edges of the shelves. Sand the ramp back until the surface is completely smooth. Apply a coat of prime, followed by 1 coat of white wall paint.
Step 6
Add your chosen material to the ramp top.
Step 7
Upon installing the ramp and observing Charlie using it, I realised the carpet was far too slippery. I then replaced it with these great foam-based self-adhesive panels.
Old-gal24
Re: Hamptons-inspired dog ramp
I was also wondering the same @AnnieOzi  @Alicia_Woodwork
I have mini dashies, and have to watch their backs.  Along with a few other smaller dogs.  this is a great way to make a boring old ramp, useful storage.
This old gal
Old-gal24
Hi Eric @EricL
Thanks for the input.
This old Gal
muzzler
hamptons dog ramp
 I would like to know the measurements and detailed instructions on how to build the Hamptons dog ramp.
Re: hamptons dog ramp
Welcome to the Bunnings Workshop community @muzzler. It's sensational to have you join us, and many thanks for your question about this amazing project.
Let me tag @Alicia_Woodwork to see if they can provide those details about their project. As this is a member-submitted project, they are unlikely to have created any detailed instructions or plans. However, I trust we'll be able to help you recreate this project for yourself.
Hi @muzzler
I’m so sorry but I don’t have any plans as this was built as a once off. I’m more than happy to answer any questions you may have though or clarify any of the steps 😊
Thank you so much,
Alicia
Hi @Old-gal24, thank you so much for your comment. I can definitely recommend building ramps that serve more than one purpose as they then become part of your everyday life too. Please let me know how you go on building/sourcing a ramp for your beautiful mini Dashies 😊
@Alicia_Woodwork
Hello Alicia,
Could be a while till I get mine done as I'm moving house and have many jobs to tackle prior to getting to this one.
Many thanks for your reply
Old gal
