Hamptons-inspired dog ramp
Alicia_Woodwork
Having an Impact
My gorgeous Goldie, Charlie, was recently diagnosed with hip displacia. This condition makes ordinarily simple movements incredibly difficult. It is for this reason that I decided to build a ramp to allow her easy access to some cuddles on the bed. I worked hard to match the bed frame and decor in the room with bright whites and paneling to finish.
Materials
Tools
Ryobi Drill
AEG Drop Saw
Ryobi Disc Sander
Steps
Step 1
Build the frame using 35x70mm untreated pine. If adding shelving or draws, ensure this is calculated in the frame build. Secure the frame with 75mm 10G Timber Screws.
Step 2
Carefully cut pine cladding to size and secure using 30mm 8G timber screws. Be sure to counter sink screws using a larger drill bit.
Step 3
Using 3mm coated MDF board, measure and cut shelving lining. Secure in place using indoor wood glue and 20mm 8G screws.
Step 4
Measure and cut the 9mm MDF top. Secure using countersunk 50mm 10G timber screws. Patch all screw holes and imperfections.
Step 5
Use white gap filler to seal the edges of the shelves. Sand the ramp back until the surface is completely smooth. Apply a coat of prime, followed by 1 coat of white wall paint.
Step 6
Add your chosen material to the ramp top.
Step 7
Upon installing the ramp and observing Charlie using it, I realised the carpet was far too slippery. I then replaced it with these great foam-based self-adhesive panels.
Re: Hamptons Inspired Dog Ramp
Welcome to the Bunnings Workshop community @Alicia_Woodwork. It's marvellous to have you join us, and many thanks for sharing your tremendous project.
What a thoughtful and functional project! I trust your furry friend really appreciates the effort you've gone to. You've really nailed the styling too and the overall project looks fantastic.
Many thanks for sharing, as I am sure many of our members will be inspired by your efforts.
Thank you so much Mitchell. I’m looking forward to posting more of my projects on here. My goldie has definitely appreciated the ramp install! 😊 thank you for your kind comments - Alicia
AnnieOzi
Re: Hamptons-inspired dog ramp
Do you have details/link for foam based panels. What a good idea.
Hello @AnnieOzi
I totally agree with you it is an amazing ramp. Let me tag @Alicia_Woodwork to make them aware of your question. A possible alternative you can use is Eva 50 x 50cm Black Solid Interlock Foam Mats - 4 Pack. It is easy to cut and form, plus you can interlock the sheets to get a nice straight line up.
AnnieOzi
Thanks, Eric. We also need something softer or ribbed for a smaller dog’s paws!
Hi @AnnieOzi
Thank you for your comment 😊 I used self-adhesive foam wall panel sheets from Kmart for the top as they offered heaps of grip!
Hi @AnnieOzi,
Have you seen our Ideal DIY Floors 900mm Black Anti Fatigue Rib Foam Matting Roll or NuPlastex 65cm Island Swirl Anti Slip Decorative Matting? Both of those products could likely suit your needs.
AnnieOzi
Great. Will go and have a look.
