Our open shelf display unit needed an upgrade to something more functional that could hide the mess. I’ve added further legs to elevate the design even more!
see before photo below:👇🏻
Materials
Tools
Flexi Storage 2x2 white clever cubes
Flexi Storage Clever Cube Rattan inserts x2
Flexi Stirage clever cube H insert white
Adoored 3/8 Vertical Leg plate 2 pack x Adoored 150mm Pine Square Tapered Furniture Leg x 4
Screw driver
Steps
Step 1
1/11 ) Assemble the clever cube and cube inserts according to instructions.
2 ) measure Furniture legs bolts but screwing them into the vertical leg plate and shorten bolt to the right length.
3 ) Unscrew legs and attach Vertical leg plates on each corner of the bottom side of the cube using screw driver or a power screw driver.
4 ) Attach legs by screwing into the vertical leg plates.
5 ) Now Time to decorate!
Re: Cube shelf that’s stylish and functional!
Welcome to the Bunnings Workshop community @Simply_Bea. It's sensational to have you join us and many thanks for sharing your fabulous project.
What a simple and effective upgrade to your Flexi storage unit. It's amazing what adding some legs can do for the overall look. You've really created a functional and charming centrepiece for your room.
Those rattan inserts are terrific. I hadn't seen them in the range, so thanks for bringing them to my attention.
Well done, and thanks again for sharing.
Thanks Mitchell, It’s great to be here and hope learn more and get inspired by the community to do bigger DIY’s in the future! 😊
Subject | Author | Posted | |
November | |||
August | |||
January | |||
September | |||
August |
