Bedroom Makeover for my daughter using Easy Craft VJ panelling and picture railing.
Materials
Tools
Plunge Saw: https://www.bunnings.com.au/ozito-165mm-1200w-plunge-track-saw-kit_p6290615
Gorila wood glue: https://www.bunnings.com.au/gorilla-236ml-wood-glue_p1662680
Nail Gun: https://www.bunnings.com.au/paslode-16ga-trimmaster-cordless-angled-bradder-kit_p0369825
Cutting in brush:
https://www.bunnings.com.au/monarch-38mm-cutting-in-and-framing-synthetic-paint-brush_p0319007
Roller Kit: https://www.bunnings.com.au/uni-pro-230mm-10mm-nap-you-can-do-it-paint-roller-cover_p1660040
Painters Tape: https://www.bunnings.com.au/frog-tape-24mm-x-55m-delicate-surface-masking-tape_p0088299
Steps
Step 1
1/9 
Measure and Cut panelling to size using your track saw.
Step 2
2/9Place panelling on wall, connect the panels using the Gorila glue at the joins. The panelling will click into each other.
Step 3
3/9 
Once all panelling is on the wall secure with nails.
Step 4
4/9
Punch nails using a nail punch and fill with putty. Once dried sand back in preparation to paint.
Step 5
5/9
tape up wall for Paining
Step 6
6/9 
Use a cutting in brush to cut in and paint the grooves.
Step 7
7/9While the paint is still wet complete the area with a roller.
Step 8
8/9 
Place skirting and picture railing on, punch and putty the nails and paint your desired colour.
Step 9
9/9 
BEFORE PHOTO:
Re: Bedroom makeover using VJ panels
Thank you! So true, I find the panelling can transform the entire space. Very happy with the outcome
Thank you! It was definitely easy to do and I think any beginner could give it a shot
Thank you! they are from Adairs
- « Previous
- 1
- 2
- Next »
