Bed frame makeover
CreativeKeola
Bed frame makeover
This bed screamed late 90's  with its orange timber stain, though it was sturdy and strong,  i decided it needed a revamp to give it new life and be enjoyed for another decade or two
Materials
  •   80 Grit Sand Paper
  • Sugar Soap
  •   Painters Tape
  •   1 Litre -Watson Feast Liming White
  •  Foam Roller
  •  Thin Paint Brush
  • 4 Litres of Porters Paint  in "Squid Ink"
  • Drop Sheets ( i used a old Tarp and Sheet )
      * All my Materials listed came from Bunning's           excluding the tarp and drop sheet
Tools
Ryobi Orbital Sander
Steps
Step 1
Took apart the bed frame and gave a good clean with sugar soap to get any grime of the frame - rinsed with clean water and wiped over and let dry completely.
Step 2
Gave the Bedframe a entire light sand using 80 Grit sandpaper, wiped down again and let drybefore bed 1.jpeg
Step 3
Sanded the top of the bed head and the foot to raw timber.
Using a vacuum, i vacuumedbed before 2.jpeg up any lose sawdust and gave a wipe down again.
Taped up where i didn't want paint to be
Step 4
Applied 2 coats of Porters Paint to each side allowing 2 hrs
in-between coats.
using a paint brush and then going over with a foam roller to get a matte flawless finish.
Applied 2 coats of Watson Feast Liming White to the top of the bed head and foot head.bed finished 2.jpeg
Re: Bed frame makeover
Hi @CreativeKeola,
Thank you for sharing your bed upcycling project.
The Porter's Squid Ink Paint looks brilliant and your choice to limewash the top of the frame gives a fantastic contrast.
I bet you're happy with the results after the huge amount of sanding.
Congratulations on a wonderful project.
