What screws to use for 3mm MDF lining?
starofbasel
Lining with 3mm MDF. What screws are best to put up curtain bracket
Community manager's note: Check out How to choose the right screw for the job for expert advice.
Re: 3mmMDF
Hi @starofbasel,
Typically curtain brackets need to be screwed directly into the timber stud work or, at a minimum, attached to 10mm plasterboard. If these are very lightweight curtains, then you could get away with fixing the bracket to the MDF with spring toggles. I recommend the toggles as any screws you use will likely tear out of the MDF as it is so thin.
Re: 3mmMDF
Hi Mitchel, I have a vintage caravan. I left the plywood in, put a car insulation think foam on top of it and covered the insulation with 3mm MDF. I need a screw that catches the 3 layers. That is the best tread for that?
Selina
Re: 3mmMDF
Thanks for the additional details, @starofbasel
Those expanding toggles won't work if it is a foam core inside the wall. Standard timbers screws will likely do the best job and catch all layers. Make sure you pick up some that are just long enough to go through all three layers. You don't want them bottoming out and hitting the outside skin of the caravan. Also, look for screws like the one I've linked to that has the thread all the way to the head. This will ensure that the first layer of 3mm MDF is captured.
