Hey Everyone,
I recently moved in to a home and realised that the rangehood is not working. I then decided to remove the unit and purchase a new one.
Once i removed it, i realised that I do not have any ducting connected to the rangehood and then I did my research and understood that there are 3 ways going about this:
1. Install ducting to a flume.
2. allow fumes and oils to go to the attic (space between ceiling and roof)
3. allow fumes and oils to go to the buffer space between the cabinets and the ceiling (can be seen in the photo).
I am unsure if the fumes and oils are actually going to that buffer but i saw that at the top of the White wooden box in the first image it is blocked by insulation. is this normal?
I am unsure what to do here. Should I leave this as it is? Do you reckon the fumes are going to the soffit? Do you think i need to get a ducting kit?
I would really appreciate your help and support.
Ramzi
Hi @ramzyatallah,
It appears that an attempt was made to either vent to the roof cavity or install a ducting kit.
You have two options that comply with safety restrictions: to use a ducting kit to vent to the soffit/roof tile vent or to pick a non-ducting unit that recirculates the air back into the room after passing through a filter. Venting into a cavity in the cabinetry or into the roof space is not permitted as it is a fire hazard due to the build-up of grease.
It would be my advice to contact the rangehood manufacturer to ask them about the required installation guidelines for their unit and to acquire any parts needed to attach a ducting kit. You can then duct the unit to the soffit with a rangehood ducting kit. If it were one of our units, I'd be happy to contact the manufacturer for you.
Thanks @MitchellMc I really appreciate your help for this. This is very helpful. I ll communicate with thr manufacturer and surely end up going to bunnings for supplies.
I hope you have a great day👍👍
Ramzi
