New subway tile kitchen splashback
ProjectPete
Given we were going to do a full kitchen reno but we're instead building a new home, we thought the splashback could at least do with a facelift, especially with how stoked we were with how our laundry reno turned out.
So here's a few pics of the process....
Before
Check out the ghastly powerpoints and red exposed on the tiles...
So off came the builder spec tiles (mmmmm satisfying)
Then as with any job, prep prep prep...
Getting the first row right is critical so take your tie, use your yellow wedge spacers and a spirit level if things are a bit off. I was going on a flat bench in great cond so no real issues for me but something to keep in mind especially if you're bridging a gap for example.
As you move up the wall it gets messy but don't stress, all that excess adhesive is easy to scrap/wipe off once it's all dry. To avoid too much mess a) don't overdo it with the adhesive, and b) just before you place you next tile run you finger along the side and top of the tiles it'll be going next to - it reduces the amount of adhesive that seaps out when you apply some pressure.
I used a grinder for all my cuts which I find easier for these small (200x100) subway tiles - you just need a steady hand. Obviously a tile cutter is a better way to go for the big tiles. Remember that if you use a grinder you lose about 4mm of the tile for your cut so if you cut a 200mm tile in half at the 100mm mark one piece will be 100mm and the other about 96mm - this is not good when following a pattern so keep the 96mm piece for small cuts you might need to make.
Always work with a clean station - it makes for a better end product. I thoroughly cleaned the tiles before startign the dreaded grouting stage. Again, when grouting the excess that gets on the tiles is easy to scrape/clean off so don't let it get to you. One thing I will note is that I personally find it better to focus your grout on the gaps needing grouting rather than smearing it everywhere like some people suggest - saves you cleaning up too much after and I feel it gives a better finish.
Note from the pic above what this would've looked like with a darker grout which is also common with subway tiles. We went with white to a) make the space look a bit bigger, and b) appeal to more tastes (given we're selling in a year). Make sure you seal the grout!
Grouting is done, bit of cleaning to go and silicone for the edges which means it's time to start celebrating :smile: Any excuse'll do for a beer, right?
Once the (tedious) silicone is done and the new white slimline powerpoints are on, time to replace the appliances and get the 'after' shot.
After
Would love to hear what you think...especially if you (honestly) think it'd make a difference to you opinion of the kitchen as a potential buyer.
I'll also be adding some box shelves in the whitespace next but was keen to share this now.
Looking forward to sharing the next one with you :smile:
Handy and helpful
Re: New subway tile kitchen splashback
Visitors to this very popular discussion should also check out @ProjectPete's excellent guide How to tile a splashback.
Please feel free to post if you need a hand with anything.
Old-gal24
I know this post was some years back now @ProjectPete but have been trying to figure out what I am going to do re; a kitchen revamp I am about to start..  God help me...
I think this looks great BUT did you manage to put in any upper cupboards or shelves?  I do love the tiles look awesome.
I am toying with either 1)  New tiles over the top of old ?   2) Digging out the old tiles and tiling 2)a & installing pressed metal splash backs  3) Painting existing tiles.  Along with other things..
Keep up your great work and keeping us L plate folk posted.
Old gal
I just put in a shelf on each side @Old-gal24 which we decorated with some cooking books, candles, plants, etc. I wouldn't recommend tiling over tiles due to lack of adhesion to such a smooth/shiny surface. Plus you'll then have tiling that's about 25-30mm thick protruding from your wall. I haven't painted tiles myself but see a lot of people do - appears to be a simple and cost-effective solution.
Handy and helpful
Improvements
I think using a dark contrasting grout would have made it pop. Gotta love your beer commercial too!
Thanks for joining in the discussion @Improvements
Welcome to the Bunnings Workshop community. It's terrific to have you join us.
Looking forward to reading about all your own projects and plans for around the house and garden. We're sure you will get plenty of helpful information, advice and inspiration from our amazing community members. Feel free to post anytime.
