How to repair torn drywall paper?
Gary_Loomes
Workmen installing a new kitchen tore the dry-wall paper while removing the old kitchen. The "flaps" are still intact and can be well aligned if there is a simple way to "glue" then back in place. Or will I have to cut them away and do a major repair job?
Re: Torn drywall paper
Welcome to the Bunnings Workshop community @Gary_Loomes. It's great to have you join us, and many thanks for your question about repairing the paper coating on plasterboard.
I'd suggest mixing up an 80/20 mix of PVA glue and water and applying it under the paper. Tape the paper back in position until the glue has dried. You could use the PVA neat, but it's a little thick and will flow better diluted.
Depending on how neatly you can glue the section back down, it could solve the issue. I believe it's certainly worth a shot before moving on to more extensive repairs.
