Hi, There
I recently have laminated benchtop installed, but the installer didn’t use the benchtop joiner and end up with unpleasant gap at joint. He used some sort of silicon to fill it but really it doesn’t work, it comes off very easily.
I did some researches and found people talk about polyurethane glue, wood saw dust mix with resin etc.,
it will be appreciated if anyone here can guide me what is the best product to use to fill the gap, prefer hard, rather than silicon as it is kitchen Benchtop using for food preparation, the bench-top is wood colored laminated.
Cheers
Ben
Hi @benzz,
Can you upload some photos of the benchtop? This will help our members offer their best advice based on your specific benchtop.
As the benchtop is laminate, then the timber colour of the face is usually a veneer applied to chipboard meaning gathering sawdust to create a filler might not be an option.
Epoxy fillers like this Utility Epoxy Adhesive could be an option if you can mix it with sawdust, but as I mentioned before, gathering sawdust could be out of the question.
Timbermate make a range of wood fillers in a variety of colours to match common timber species. This could be an option, but they are still relatively soft.
Applying some Timbermate Wood Filler so it sits just below the surface of the timber, allowing it to fully dry and then applying epoxy adhesive sounds like a good option.
Alternatively, you might like to consider installing some benchtop connectors to pull the gap together.
Let me know what you think.
