Hi, I'd like to have a go at painting the kicker strip between my cupboards and flooring to change the colour from black to white (pic attached).
Is this an easy job and what equipment/technique should I use? Perhaps it might better to hire a painter !
Thanks for any advice.
hi @jwilliamson
This is a nice DIY job
First mask your floor with no bleed masking tape. Then add a painters drop sheet across the floor.
Those kick boards can be vinal or melomine which resists paint sticking to it so best to under coat.
$35.98
Medium brush water based
The undercoat also masks the black dark colour so the white is bright as intended
Hi @jwilliamson,
It's great to see you've already received some helpful advice from @Jewelleryrescue. The only thing I can add is to make sure to give the kickboard a good wipe-down with some Sugar Soap to remove any greasy residue before priming. Dulux Aquanamel would be a great choice for your topcoat paint.
@MitchellMc @Jewelleryrescue Hi,
Well I painted my kitchen kickboard over the weekend but perhaps I should've left it to the professionals. It looks okay but when I pulled off the tape (still partially wet), I took off the paint with the tape so it's left this ripped strip of black at the bottom (see pic). I have heaps of Primer and Paint left so is there any way to rectify this with another coat over the bottom? Maybe I'll hire in a painter to fix it instead! Also, I've left a few splashes of paint on the hybrid floor so how best to remove ?
I used the Dulux Aquanamel. Thanks so much for all of your advice. Cheers Jan
Hi @jwilliamson,
That can happen to the best of us. I'd take a small paintbrush and touch up the areas.
You'll find the Aquanamel shouldn't have adhered all that well to the flooring. Try scratching the majority off with your fingernail and then pop some warm soapy water on a sponge or rag and give the area a bit of a scrub. That should remove most, if not all, of the splashes.
Thanks @MitchellMc Do I just use the paint and not the primer? The small paintbrush link didn't work so is this the 25mm synthetic brush. Could I also use a small foam brush? Thanks again! I'll try that...
Any craft brush will do, @jwilliamson. The 25mm is a little large unless you were to re-tape the floor.
Another option is to add a self-adhesive quad moulding around the floor's perimeter. Not only will that hide the paint job, but it will also give you an excellent finish.
Hello @jwilliamson
If the moulding is unprimed and is just plain timber, it's best to use the primer on it before you paint over it. This will give the topcoat a good surface to grip on.
Hi @jwilliamson
Really I would leave your white floor masking tape line and use no more gaps to seal between you kick board and floor you can then over paint as you wish.
Your efforts to date is as good as a many pro painters I have seen. Practice will help you so dont sell your efforts short It is your home so step back and ask your self do I like that white line on the floor. Personally I do once you seal the gaps to the floor it will look neat and even after a final paint coat I think you will be pleased
A heads up every DIY person thinks there work can be better as we can all see the little blemishes we make . But no one else ever will so you need to follow your standards aim high but dont fret the little blemishes if they occur.
