How to fix hinge on Kaboodle kitchen corner cupboard?
Hello. Recently bought a house with Bunnings Kaboodle kitchen. Having issues with the corner cupboards. The sliding but of the hinge keeps slipping. I tighten it up with screwdriver and it last a week before slipping again. On one of them, the door was not flush with the other part of the door. They are now but issue keeps occurring.
Any suggestions?
Re: Bunnings kaboodle kitchen crn cupboard
Hello @MeganHardy
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your corner hinges.
It appears that the screw is ever so slightly slipping allowing the hinge to slide away from its anchor. I suggest removing the screw and putting a few drops of Loctite 243 10ml Adhesive Threadlocker to stop the screw from coming loose. Make sure to position the door correctly before locking the screw in place. If the hinge continues to slip, I suggest proceeding to the store and replacing them with a new set.
Thanks for the advice. Ended up replacing screws and all good now.
