How to clean laminate benchtop?
Hey All, I need some recommendation on products that I can use to clean my terrazzo kitchen laminate benchtop. Its almost 5 years old and looks like there is discoloration due to use and build up. Attaching photos for reference. Thanks in advance you all😊
- Labels:
Cleaning
Tools and Materials
Re: How to clean laminate benchtop?
Hello @anugogia26
Welcome to the Bunnings Workshop community. It's marvellous to have you join us, and thanks for sharing your question about your laminate benchtop.
I propose starting with a mild cleaner such as dishwashing liquid and a non-abrasive scrubber such as the Scotch-Brite 155 x 100mm Non-Scratch Scourer Pads. Use warm water to remove any oil or grease deposits. I can't recommend strong chemical cleaners as laminate surfaces are sensitive to strong cleaning chemicals that are acid based.
I also suggest having a look at the White Knight 500ml Tile And Laminate Cleaner. This cleaner is made to clean tile and laminate surfaces. If either method fails to produce satisfactory results. I recommend engaging the services of a benchtop restoration specialist. They will have the knowledge and equipment to safely restore the surface of your laminate top.
