Hello,
I want to install a blind corner pantry, but have a question about the filler panel. Can I make it flush with end of cabinet so pantry is flush with the wall.
There will be no cupboards adjoining it so I don't see the need for the 200mm over hang.
cheers
Hello @haydenv72
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about installing a blind corner pantry.
The blind overhang panel technically is there to push the pantry past the cabinet that will be facing it. But since nothing is going to be put next to it there should be no issue with having it flush to the end of the cabinet.
However, I suggest installing the pantry door first then the side cover panel. This will tell you if the panel is going to overhang. If that is the case the side cover panel will need to be resized.
Here is a link to the Kaboodle brochure: Kaboodle Blind Corner Pantry Assembly.
