Our kitchen has black grout basically throughout and we are looking for the best way to change it from black to white. Is there any good staining products we could use or would we need to remove the grout completely and regrout with white?
Hello @rff91
Thanks for sharing your question about changing the colour of your grout. I'm currently not aware of a good staining product that will transform your black grout to white. I recommend removing the black grout and replacing it with white for best results. I suggest using a Multi Tool with a grout blade to remove the black grout. In order for you not to get overwhelmed with the process, I propose doing it in sections. In this manner you will clearly see the progress you are making as you move from one part of your wall to another. This also has the advantage of minimizing the disruption in the function of your kitchen.
