XU1 Grass Trimmer battery replacement XLBP-0185
Hi! I had bought XU1 Cordless Grass Trimmer (XGTK-0185) from Bunnings. Needed another battery (XLBP-0185) but couldn't find one at Bunnings. Also needed the blades. Could you please suggest alternatives?
- Labels:
Gardening
Tools and Materials
Re: XU1 Grass Trimmer battery replacement XLBP-0185
Welcome to the Bunnings Workshop community @victorbpaul. It's wonderful to have you join us, and many thanks for your question about XU1 batteries and blades.
Additional batteries are not a stocked line, so if you speak to a helpful Special Orders team member at your local store, they can check availability with the supplier. The blades should also be available through Special Orders, but if you want them sooner, the Ozito blades are compatible.
Hi Mitchell,
Thank you for your prompt response. Will definitely get in touch with the Special Order team member. I think I will pickup the Ozito Blades. Thank you once again!!
