Whats wrong with my discoloured brown lemons?
frannie
My established lemon tree which was at the house when bought it produces an abundance of fruit.  They have small brown marks on the skin which last year did not seem to be a problem with the lemons being large and juicy.  This year many of the lemons are discoloured brown in the centre or around the edge when cut in half, but are still juicy and not dry.  Is this a disease or caused by insects and what can I do to prevent this happening next year? 
Re: Whats wrong with my discoloured brown lemons?
Hi @frannie,
It looks like you might have a case of lemon scab which is a fungal disease that affects the fruit, leaves, and twigs of citrus trees, including lemons, and is more common in humid or wet environments.
Do you have any photos of the tree that you could upload?
There may be some signs on the tree that would help to confirm this diagnosis. The fungus can cause small, scabby lesions on leaves and twigs, though the fruit is usually the most affected part.
To manage lemon scab, prune the tree to improve air circulation and reduce humidity. Apply copper-based fungicides, such as Yates Liquid Copper Fungicide during key growth periods, such as after flowering and during fruit set. Additionally, remove infected material, like heavily affected leaves or fruit, to limit the spread of the disease.
Preventing moisture buildup is crucial, along with regular fungicide treatments in areas prone to scab.
Allow me to tag @Noelle, our resident garden guru to see if she has any thoughts.
Noelle
Hi @frannie
The outside of the fruits looks very like lemon scab. However, this does not usually cause browning to the inside of the fruit. Affected fruits are usually OK for juicing but not for zesting or making marmalade where the skin should be perfect!.
The browning inside is often seen on fruits that are over-ripe and are starting to rot on the tree. This can also sometimes be caused by excessive rainfall and humidity as the fruits are maturing. Fruits that are brown inside should be discarded as they are likely to have quite an unpleasant after-taste.
The fungicide treatment outlined by Jacob will aid in the control of lemon scab but sadly won't save the current crop from the warty-looking skin lesions.
