With my last couple of Brown Beauty bean plantings I have noticed that germination and first leaf growth appear to be normal, however second leaf growth is stunted and deformed.
I have also the same issue with my Mini Roma tomato seedling. After planting growth appeared to be normal and then new growth was once again was stunted and deformed.
I have done some research and there is a possibility that this issue could be viral or herbicidal related.
As a possible unrelated observation I have a Jacaranda that has been lopped also has stunted and deformed new growth.
Any suggestion would be appreciated.
Hello @DougH
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your tomato plant.
It might be a leaf curl virus or as you mentioned herbicide related. Leaf curl often happens when you have an infestation of leaf miners, but it does not appear to have any tell-tale tracks on the leaves. I also suggest having a look at this guide - How to diagnose a sick plant by @Noelle.
Let me call on our experienced members @Noelle and @mich1972 for their opinion regarding the deformed leaves of the tomato plant.
In the meantime, I propose using Seasol on the plants and observing if any other symptoms appear.
Hi @DougH
Welcome to the Community.
If just the beans and tomato were affected then I'd suggest the leaf curl and stunted growth could be herbicide-related but it is extremely doubtful that any spray drift would have that sort of an effect high up on a recently lopped jacaranda.In my opinion, the symptoms of the vegies and unrelated to those on the jacaranda
My suspicions lie with viral disease and, unfortunately, there are no treatments available for viruses. If you leave affected vegie plants growing in your garden, there's a very high chance the disease will spread via sap-sucking insects to healthy plants. My recommendation would be to remove all affected plants, and start again in another area of the garden - don't replant into the same soil.
The jacaranda is reacting the way many established trees do - they product masses of new shoots that look stunted and crowded together. Eventually most will die due to competition, with only the healthiest thriving to grow into sturdy new branches.
Thanks for your reply and suggestions.
Unfortunately I don't have the option of moving to another area of the garden as these are raised beds in a greenhouse. I have recently had a problem with nematodes so I replaced all the soil, after washing the garden bed retaining walls, leaving empty for two months before refilling and not planting for another month.
So I am at loss as to what is the cause.
As an experiment I have planted a few bean seeds in a planter box with new potting mix well removed from the greenhouse garden beds. I will now wait and see.
Any further suggestions would be appreciated.
Regards
DougH
Hi again @DougH
Virus diseases are spread by sap-sucking insects, such as aphids and white fly, that transfer sap from infected plants somewhere in your neighborhood to clean plants. All you can do, if you do decide to start over, is to erect frames and enclose the beds in fine insect netting to try to exclude these pests, which can invade greenhouses quite easily.
If your current plants are virus-affected, they may still crop but yields and quality are likely to be significantly affected.
