What hose fitting will stop leaking where it connects to tap?
sarah71
Re: how do i find a hose fitting that will stop leaking where it connects to tap
Welcome to the Bunnings Workshop community @sarah71. It's brilliant to have you join us, and many thanks for your question about connecting a hose.
The hose fitting you've pictured is quite budget-friendly. If it's leaking when connected to the tap, then either it has failed, or the rubber O-ring on the tap adapter needs replacing. I'd recommend picking up a Nylex 12mm 3 Piece Plastic Hose Connector Set. It includes a new tap adaptor and click-on fitting for the end of your hose. There's also an additional one that you can use for your spray nozzle.
