Mystery holes in lawn
Prof
Hi Garden Gurus,
Some mystery holes recently appeared on my front lawn which I have never seen before and I'm stumped as to what has caused them...
There are about 20 holes randomly spaced across the lawn...
They are about 4" in diam ( not even..obviously dug by an animals feet) and only about 4" or 5" deep..
Anyone have any idea what might be doing this?
I live on a hill overlooking the River Murray.
Re: Mystery Holes
Hey @Prof,
Would you be able to share a photo? It might help the gardeners in the community help identify the problem.
Also, not sure if you saw this recent discussion kicked off by @bergs. The culprit was curl grubs/black beetles.
bergs
Becoming a Leader
Re: Mystery Holes
Hi @Prof do you have Echidnas about your place?
I notice there have been heaps of ants about this season, so maybe an Echidna!
I notice when I go bush that the Echidnas get into the ant's nest and and they are only small uneven holes about the area.
The other thing they could be grubs in the soil and the birds are scratching them out!
Dig one of the holes out to see if there is anything in it.
Maybe check it out at night to see if there is anything active.
Grubs chew on the lawn roots and the grass will slowly die off.
Maybe Bandicoot??
Good luck in your efforts to find the culprit
Cheers bergs
Be happy and care for your tools
Prof
Re: Mystery Holes
Here are a couple of shots of the holes..
There has been a lot of bark that has blown off the gumtree out the front..
Bergs...Interesting that you should suggest an Echidna!
When I first moved into this place I saw an Echidna coming up the driveway..
It disappeared under the fence and I haven't seen it since..
Maybe it's come back..
Re: Mystery Holes
@Prof
Thanks for the photos. Hopefully someone in the community will be able to help identify the culprit!
You might also be interested in this previous discussion about bandicoots kicked off by @Flo54 last year - https://www.workshop.com.au/t5/Gardening/Bandicoots/m-p/13314
You are lucky to live in an area with echidnas!
Prof
Re: Mystery Holes
Yes indeed Jason..I'm amazed at the number of different animals I've seen on my front lawn!
It's like a wild life reserve here.!! :laugh:
MartyH
Re: Mystery Holes
Any poo around that will give you another clue @Prof
This article might help if its a bandicoot - https://laurarittenhouse.wordpress.com/2011/04/03/is-there-a-bandicoot-in-my-garden/
Prof
Re: Mystery Holes
No MartyH..I can't see any poos anywhere near the holes, which probably rules out Bandicoots..
Re: Mystery Holes
Hey @Prof,
How are you going with this mystery. Any other clues?
BIM_Engineer
Former Community Member
Re: Mystery Holes
Google is trying to tell me it's one of these things
Hmmm
